VG33QX4 »
https://forums.nicoclub.com/vg33qx4-u162332.html
Fri Dec 17, 2010 10:48 am
so first off if you look at the data sheet 85 flows just fine above 0 degrees, coldest it gets around here is 25 like 10 times a year.
at 150,000 miles there are plenty of gaps where 140 oil can get into. an important note is that it really doesnt have any load on it when in 2wd so its not like its under huge stresses.
80-90 85w-140
Vis @ 100°C (cSt) 14.5 26.7
Vis @ 40°C (cSt) 140.1 361
Viscosity Index 102 99
Spec Gravity @ 60F 0.8911 0.904
Density (lbs/gal) 7.43 7.53
Brookfield Vis., cP 110,000(-26C) 120,000(-12C)
Pour Point, C -30 -15
as you can see the viscosity index difference is negligible. however the at viscosity at temperature rating is of course very different.
