My metra kit has started the same problem...Did you order just the center panel? Or do you need the nav brackets as well?papawu wrote:I had the same problem. The metra dash kit sucks. I ordered the center panel that fits double din stereo's.
http://www.trademotion.com/par...gid=2
Depends on the player, on my Alpine I couldn't get it to fit. I just live with the gap.GryStrm wrote:is there a way to use the metra internal mounting stuff and the OEM face that papawu got?..there is still a gap between the face and the head unit if you can see it...i wouldnt want this...the metra double din face trim would eliminate this...
did u try using the thin trim ring from the metra kit?papawu wrote: I'm glad I did since the radio looks more factory minus the gab.
Yup, but it didn't fit. But it may fit around another double din. I would like to fabricate something but I just don't have the resources down here to do so.GryStrm wrote:did u try using the thin trim ring from the metra kit?
