Front Cover/ Oil Pump
wannaS13
Car: 92 240sx
i found out threw trail and error last night that if you pull the bottom pan off of the motor (which includes two nuts behind the flywheel) and the two bolts from inside the valve cover, you can remove the front cover without puling the head. just be careful not to rip the head gasket when doing so. just thought i would post this becuase i always saw the every post said to pull the head
