slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Sun Jun 12, 2005 3:03 am
Hi there, Lately I'v been noticing a single 'clunk' from my front end(pass. side). Usually only happens once or twice durring a drive: when I first start off and am turning, or, when I'm coming to a semi-hard stop. It's not extremely loud, it's barely heard w/the windows up. Sounds like metal on metal, but deadened. FYI this is a '92 S13, ~125k on stock suspension.
Anyways after reading around for a bit I think I'v narrowed it down to the tie rod end or the upper strut bearing assy. First, my passenger outer tie rod bushing looks shot: the boot is torn and the grease inside(still some there), is old and gritty. All the other bushings look OK; cracked and dryrotted a bit, but still holding up. Second, I just noticed last night there was an oil-like substance on the top of the passenger shock tower(in 'bay). Oddly it was all around the upper three nuts, but dry underneith. My shocks are old and worn(dust boots are pratically non-existant), but I don't think they're blown: no excessive bounce or anything. Is the upper bearing packed with grease, or an oily-fluid? FWIW I have bad wheel shimmy at 50-55mph, but this was immediately after I had the tires ballanced: they said all 4 had flat spots. Also how dangerous is it to drive w/worn out tie rod ends? Should the rubber completely fail, is there still a 'fail-safe' connection between tie rod and the nuckle?
Thx for reading,-Slip
