Front Clip Help (TT Swap)
iLLMATiC93
Car: 1993 Nissan 300zx (NA)(5SP)
I will, in the future, be performing a tt swap, my question is if i buy a full front tt clip, will i be able to "slide" everthing over into my car or do i need special brackets and mounts, other than whats included? Also are there any ideas on some parts i should replace before placing it into my car?
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
First Welcome. Second, at the top of this section is a "sticky" called "Everything you wanted to know about the Z." Inside are lots of links including the swap to TT.
As a general rule, the clip will have what you need, but expect that some parts may be damaged due to shipping. It is not uncommon for the oil pan to be dented and needing replaced. A dent will kill oil pressure and the engine. Inspect the clip thoroughly and look for broken/bent components. Make sure the front fascia (bumper) is in good shape as well.
Good luck
