carmo »
https://forums.nicoclub.com/carmo-u91933.html
Thu Aug 21, 2008 2:45 pm
It looks like you got it. I can't tell about cam installation but it all looks pretty good to me. When you put those seals on, I usually use a 5inch 3/8s extension to act as a drift to hammer the seals in. Install them just pass flush and even all the way around. On the crank seal, if you haven't already installed it, be carefull not to roll the inside lip on the crankshaft while you getting the thing to fit in. Between the cam gears, tight fit and that little plate that goes between the seal and the crank gear, none of seals are gonna go anywhere. goodluck
Modified by carmo at 10:13 AM 8/24/2008
