Front Camber Correction Kit (wheel alignment)
95FairLadyZX
Car: 95 300ZX 2+0 NA
So I took the car to get an alignment because my front wheels have uneaven tire wear(inside edge is bald) :frown: The guy said I need the front camber kit to correct the alignment...
I found these on ebay
http://cgi.ebay.com/ebaymotors/SPC-FRON ... 1913wt_863
OR these? I found on ConceptZ, I know its for Eibach lowering springs but will they also work?
http://conceptzperformance.com/Cart/des ... 21.241.198
Any other suggestions?
95FairLadyZX
Oh I forgot to mention, my stock springs are sagging and I will being lowering the car in the future so would the ones from conceptZ work and be better in the long run?
NolimitZ32
Depending on how low you go those kits may not be enough and you may need the FUCAs and RUCAs
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
The 300° Camber Kitis perfect for Eibach springs. Anything lower and I would suggest Powertrix upper arms and tension rods. When you use solid bearing upper arms, you need to use solid bearing tension rods.
http://www.powertrix.com/agoracart55/ag ... Suspension
The rear has some adjustablity for camber, but not much.
95FairLadyZX
I probably won't go lower, would the SPC camber kit work with the Eibach springs?
95FairLadyZX
bump.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Don't cheap out on suspension components. If you're planning on going lower, the obvious solution is to get fully adjustable arms from Powertrix.
