Front calipers are dragging after pad changed....
Pinoy240sx
Car: 1993 Nissan 240x & 2004 Honda Pilot
After I changed my 93 240sx (w/o abs, auto) 's brake pads, the front brakes are dragging when moving forward and backward. All calipers' pistons were compressed with the brake fluid cap off...then the cap was replaced back on followed by pumping the brake pedal while car is running. Any advice on which could be the cause of the calipers dragging.
ZOMG.SR20
Car: 1990 s13
did you lube the slides? the piston could be stuck out because the seal in the caliper is not letting the piston retract all the way
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
what he said +1...
There might be some gunk in the holes that the slider pins go in. Scrape em out with a screwdriver. Or maybe your calipers are locked up?
