Rucca »
https://forums.nicoclub.com/rucca-u71259.html
Wed Apr 16, 2008 4:47 pm
The piston should be basically flush with the caliper. Sounds like it is pushed in all the way but if you aren't sure just put an old used pad over the piston and use a C clamp to force the piston into the caliper all the way. Once the C clamp becomes very difficult to spin, you know you are bottomed out. Refinishing the rotors wont take of 1.5mm, well it would take about 5 passes with a brake lathe at least. Even with an extra 1.5mm you should be able to easily slide the caliper over the pads and rotor...
Make sure the pads are tightly hugging the rotor and the rotor is held firmly on the hub (use a lug nut to keep it in place if you need to). If the shims came with the pads, try to use them but you don't need them. If needed, ditch the shims for extra clearance. Either way, it sounds like you don't have the correct pads or rotor, your caliper piston isn't fully retracted, or you just aren't sliding the caliper around correctly...
