front caliper bracket, slider pin hole solid (anyone else run into this before?)
White Comet
Car: fc, s13 and mazda6, Sierra
i hope the title isnt too confusing but i didnt know how to word it better. im trying to install q45 brakes on my s13 and i was putting new seals in the holes where the slider pin bolts go. I noticed the one hole for the slider pin bolt is completely filled in. the other hole in the bracket is open like its supposed to be, and the other brackets has both holes open. im very confused why this hole is filled in and im sure its solid metal and not just gunk. has anyone else run into this problem? i hope my question makes enough sense, if not maybe the pics will helplet me know if this post is still confusing, i appreciate any help. thank you
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Can't tell, but are you sure you are not looking at the brake pad sensor probe?
White Comet
im positive im not. its the hole the slider pin goes in that has the rubber seal (seal not shown in pics)
KA24Power
Car: 1990 240sx
looks like the slider broke off in there. get a new one, and drill that ***** out!
White Comet
i was thinking of drilling it out. but im not so sure the old one broke off. the surface is perfectly smooth, too smooth for a break. and i thought there was a narrow hole in the bottom but it was just a small rubber cap that popped out
DrewQ45
Car: 1990 Infiniti Q45
Got a few of
White Comet wrote:i was thinking of drilling it out. but im not so sure the old one broke off. the surface is perfectly smooth, too smooth for a break. and i thought there was a narrow hole in the bottom but it was just a small rubber cap that popped out
Got a few of these laying around in case you decide you need a change.
White Comet
hmmm how much?
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
I dunno jeff. I'd take a big whack at it with a hammer and a steel rod and see if it comes out. It doesn't look like from the pics that the metal in there was cast inside that hole. I mean surely it wasn't supposed to be, but there is a hole to start with so I think water made it rust and grow together or something lol.Good luck with the shenanigans. Git r done for thursday even if it's not totally perfect!
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
nvm about my brackets... mine didnt have anything like that.... i just remember a cap in the one but it was a plastic piece i think was supposed to be there... grr im tempted to take my wheels off the next time im hope to check it out, all i know is i had to try my swap three times... the first i had one rear and one front bracket...
second time i realized the cailpers pistons werent firing together so when i finally got it working i didnt notice anythin like that
White Comet
Didderson wrote:I dunno jeff. I'd take a big whack at it with a hammer and a steel rod and see if it comes out. It doesn't look like from the pics that the metal in there was cast inside that hole. I mean surely it wasn't supposed to be, but there is a hole to start with so I think water made it rust and grow together or something lol.Good luck with the shenanigans. Git r done for thursday even if it's not totally perfect!
yeah the pics are kinda crappy so its hard to tell, but its def not a separate piece of metal ( i discovered this while drilling it out) and its not all rust either. just the one exposed side rusted. that little hole you see is only like 1 cm deep so not much luck there. i drilled it out i just need to make it a little bigger then i'll be all set
DrewQ45
White Comet wrote:hmmm how much?
$25 shipped.
Modified by DrewQ45 at 4:32 PM 4/18/2008
White Comet
^ thanks, i woudl have jumped on that, but i figured what the hell and started to drill mine out. im pretty sure i can get mine to work, but if not i'll take you up on that
