front bumer removal and instal
Sdavne
Car: Nissan 300zx n/a 2+0 5 speed sliver
90 zx. Na I am having trouble removing my frontbumper please help I can't get to bolts behind headlights and fog light bold of stripped. Please help thank you Scott [email protected]
bbecker17
Car: 1991 240sx.... dead
1990 300zx tt jdm
make sure you already got the turn signals out they come out with just 2 screws after that you can usualy a 1/4 inch ratchet in there to remove bolts, if ones stripped try to pry down on the bolt with a flat screwdriver while you loosen the bolt with the ratchet
Sdavne
thanks for the responce, yeah the right fog light is striped imight try and screw it out, but how do i get the boltd behind the headlight someone tol me to take off the molding around the lights but i tryed and ther is not alot of room thats where i am really stuck... any thoughts thanks Scott Davne
NolimitZ32
Gotta come in from the bottom (if you're referring to the bottom back bolt that is)
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
If you're trying to take the fog light out with the screw in the front, that's not right. That is the adjustment screw. There are 3 nuts in the back of the fog light the you can access through the turn signal hole.
And yeah, the best way to get at the headlight bolts is through the bottom. The front bumper is kind of a pain to remove/install.
Sdavne
that helped alot i could not figure out how to get the light out thank you.
