I am replacing the rotors on the front brakes of my 1985 2WD 720 with Z24 motor. Each of the old rotors was fastened with six bolts. Each bolt had a shoulder built into the head, and each bolt ALSO had a split lock washer under the head. However the factory microfiche DOES NOT show any split lock washers. Probably the rotors were replaced by another owner?
Does it matter if I use new bolts without the shoulder head?Why wouldn't the factory use lock washers in this application?Should I use some blue medium strength Loctite when I re-assemble them? The blue #242 Loctite is only rated to 300 degrees F. The rotors will get hot, but I can't imagine the hubs and bolts getting to 300 degrees unless something is seriously wrong.
FYI the bolts are 9 mm shaft, with a 14 mm head and are 31 mm long without the head.
I am new so thanks in advance for any advice.
Richard
