front brake piston?!!
crypt2k
Car: cars, women, what else.
Hi guyz... well im here changing the front brakes but i forgot how to push the piston back. So it doesnt let me put in the new THICKER brake pads. I've done this before but it was a while back so im not sure of the entire procedure.
all your help is appreciated.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i use channel locks, or sometimes a piece of wood and a C clamp.
crypt2k
tenkawa_akito wrote:i use channel locks, or sometimes a piece of wood and a C clamp.
i dont have any of those tools. Is there a simpler way. and you said a piece of wood. How do i go about doing that?
Hijacker
'94 F-150
i use a piece of wood and place it on the piston, then take a C clamp placed on the wood to compress the piston back in. The wood is there to allow the C clamp to apply its force to the piston more evenly.
You don't even have a set of pliers? Anything that allows you to squeeze the piston back in is all you need.
Channel locks are a set of pliers that have different ruts on one handle and allow you to change the pivot point of the plier.
crypt2k
tenkawa_akito wrote:i use a piece of wood and place it on the piston, then take a C clamp placed on the wood to compress the piston back in. The wood is there to allow the C clamp to apply its force to the piston more evenly.
sorry man. ima go try this... the tools i got, I was just not sure about how to go about doing it.
Modified by crypt2k at 5:54 PM 10/14/2004
edit: thanks man... it worked. now i got ANOTHER challenge.
...what happens when you take all 4 lugs off and the wheel still wont come off? guess i gotta buy some lube.
Modified by crypt2k at 5:56 PM 10/14/2004
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Kick the tire or get something to pry on it a bit. Shouldn't be stuck on there too bad as I imagine it's just corrosion.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Lol, just pull really hard. Its just stuck to the hub.
Or, jack the car up a little more b/c the tire is still touching the pavement.
crypt2k
yeah... i kicked the hell outta the tire today. gonna get some lube soak it over-night and kick it some more.
