GoldenR50 wrote:so i've noticed a noise coming from the front left tire when the car is moving. its more like a creaking noise that speeds up as i accelerate. this has only occured after the front pads were changed to the thermoquiets. any ideas? the noise is extremely apparently when making left turns or simply turning the wheel to the left while driving and dissapears when turning right....im thinking something is rubbing....at around 40kmh it starts to sound like a train...chugga chugga chugga...
1-Check tire seat to rim
2-Verify torque setting rim to hub
3-Float section of caliper at flex rubber stays, open 2 small bolts, lubricate inside with rubber grease, caution do not over tighten, see manual for torque.
4-Verify the piston(s) operation is smooth and no leaks
5-Rub hands on tire tread 360 degrees and feel for tire wear, cupping, then inflate to max on tire side wall and check for squareness of tire tread to rim side looking for 90 degrees. If way off an alignment will help, lower tire pressure to normal
6-If no real evidence of problems, with car on even floor, tires corrected pressure, tires straight ahead unladen:
measure floor to wheel arch checking for car sitting height...check your book for height
measure with a tape measure between front of tires, right side to right side left to right wheel, center to center then left sides of wheel to left side. Does the wheel(s) track parallel to each other, are both front wheels going the exact same direction
7- grasp the front wheels while off the ground and try to move them top to bottom in/out and then side to side...there should be no movement if there is, lower ball joint, or tie rod end. If your not strong enough use a 5' pry bar under raised wheel and try to lift the car at the wheel, feel at the strut tower for movement or banging sounds, ignore the torsion spring rising and falling as you pry up the tire assembly.
Be patient and safe while doing these make notes of what you find and get back.
