Front brake noise..Rotors?
ladyq45
Car: infiniti q45
Hi.. I have a 92 q45 I just had brake pads replaced ,, but I still hear a roaring noise from the front wheels when I stop ,could this be the rotors ? and what kind of rotors to get drilled or slot?.. yes I did do a search it seems some say no drilled or slotted.. Thank you
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
OEM pads? OEM rotors? We can't tell from here, so you need to tell us.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
what do you mean by a roaring noise? Does the steering wheel wobble when you stop?
Slotted is okay. Drilled not so much.
I doubt the sound is caused by rotors though. Even terrible rotors with new pads will be quiet.
Were the pad edges properly greased? Did they leave out or misinstall any clips?
ladyq45
Car: infiniti q45
yes the steering wheel will wobble when I brake at a speed of maybe 40 mph and up..by a roaring noise I mean like when you need brakes because they are real low.and now its a squeaking noise also . the brake pads were put on about a month ago.
elwesso
2007 BMW M Coupe
Hmm... Im not sure why the pads would make noise, all bets are off if you didnt use OEM brake pads though.
boznuttz
Car: MS13
its brake pad material on the rotors. that stuff can and WILL deposit, i just soem off of my s13 with some sand paper. its easier to solve that you think.
