Front Bearing Replacement
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
hummer3t
Car: 2013 Infiniti QX56
Frozen top bolt, drivers side. Won't budge even using an impact wrench. Have used Blaster and Free All without luck. Any suggestions?
mdmellott
Car: '13 Kia Soul+ 2.0L AT
I've had a set of Craftsman nut/bolt extractors for many years that has always worked for me when the hex head of the bolt or hex nut has been rounded off like that. Intense heat helps as well but that's a tough area to be using a torch or an induction heater for bolts.
nut extractor.jpg (34.29 KiB) Viewed 78 times
hummer3t
I do have a set of bolt extractors, both SAE and Metric that I have used, but still no budge. Tried heat and still won't budge. Noticed a You Tube video removing the steering knuckle to access the bolt. Not sure I want to go that route.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Since you're replacing the hub, you can always just grind off the head and replace the bolt. If you split the knuckle from the LCA you might be able to make enough room for a cutting wheel.
hummer3t
Where can I locate accurate torque specs for the bearing and the axle nut? Getting various info.
VStar650CL
Technical Expert
The hub-to-knuckle bolts and the axle nut are all 90 lbs/ft. See FAX-7 and FAX-17 here:
https://www.nicoclub.com/service-manual ... %2FFAX.pdf
Return to “Armada Forum / QX56 Forum / QX80 Forum”
