Front axle replacement
dbertheau
Hi,
This is probably a silly question, but---I'm replacing the front axles in my 1997 QX4. When loosening the bolts that attach the axle to the main drive, the drive/axle rotates --how do you lock the drive/axle so you can loosen, and then tighten the bolts?
Thanks,Dave
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I am not sure myself but I am sure the procedure is listed in the service manual: http://Nicoclub.com/FSM
dbertheau
Actually, I have the service manual and it simply indicates to remove the bolts!
I used a screwdriver between the other bolts on the flange and as the axle turned the screwdriver came to rest against one of the cross members and locked the axle. Kinda a pain, but it got the job done.
Dave
