Front anti sway bar bushing question
quikdime
Car: datsun 510 & 240 sx
I purchased a s13 with no drivetrain. It has a suspension technique front bar that measures 1-1/8 =28mm. Now the question...Who makes a 28mm front anti sway bar bushing that will fit the factory 240sx mounting bracket? The reason I need the factory mounting bracket to be used is this...I installed the syko performance rb kit. However, the anti sway bar spacers that are used in the kit utilize the factory anti sway bar mounting bracket not an aftermarket bracket like suspension technique uses. Is there such an animal?
Thanks In advance.
adrianfromthecastle
Car: 1992 Nissan 240sx
umm..
have you tried searching for suspension techniques bushings and brackets?
Also, energy makes bushings and brackets as well. Costs maybe around $25 or so.. I dont remember
quikdime
I have suspension tech bushing & bracket. I don't have the stock bracket.
Slappy
Car: 1993 240 sx coupe
quikdime wrote:I installed the syko performance rb kit
I read thier RB install article in Super Street awhile back. Very good company.
adrianfromthecastle
quikdime wrote:I have suspension tech bushing & bracket. I don't have the stock bracket.
wait, then what's the problem again? The mounting points on the ST sway bar brackets are the same as oem brackets. And just to clarify, we're talking about the "D" bushing brackets right?
