Front alignment/camber?
itssr20
Does the front suspension on a nearly stock S13(ST springs and AGX) have any camber adjustability? Just curious b/c I had my car aligned a month ago but then I changed the strut mounts b/c mine were all cracked. Hopefully I didnt get my alignment all out of whack!!
book-ends
Car: ???? Nissan 240SX coupe S13
Chances are you are going to have to get realigned because simply untorquing and re-torquing the bolts will screw up the alignment a little bit. It shouldn't be that big a deal though.
