crackler »
https://forums.nicoclub.com/crackler-u26495.html
Tue Feb 24, 2009 12:08 pm
Actually toe helps you change direction better. Well depending on how you set it, and can also give you better stability. And caster effects how much effort it takes to turn the wheel, and the dynamic camber curve. And you want negative camber,so when the car leans in a corner, the tires with the most grip (inside) stands straight up, giving you a better contact patch.
Or maybe I live in an alternate reality.
