slow s13 wrote:you either have the wrong rotors or your trying to put the later model rotor 30mm into the earlier narrow Z caliper 26MM??? eithere way you have the wrong rotor or are doing something way wrong.
if your calipers are alluminum and from a 90 its possible there the narrow ones if there steel you have the wrong rotors for shure
bingooozerodameaon wrote:yeah iv run into this problem a couple times. 30mm rotors on 26mm calipers.
i had a buddy put drilled 30mm brembos on. understandbly he dident want to take them off so he just had them turned down to about 28mm. surprisingly it worked.EnjoiNismo wrote:bingooo
