from where we can buy the cf
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
kifah
Car: 2008 infiniti ex35
from where i can buy the compact flash for the ex35 and also the ldw systen
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Any major online electronics retailer sells them, just make sure to not get anything larger than 2gb. I reommend the Sandisk brand.
specialist23
why not larger than 2 gb? i'm using an 8 right now and it works just fine. from sandisk.
dividedhighw
Car: 2008 EX35 AWD (Technology Pkg)
specialist23 wrote:why not larger than 2 gb? i'm using an 8 right now and it works just fine. from sandisk.
It's not that higher capacity cards don't work, but the 2 GB size is about where you will hit the limits shown in p4.48 of the EX Owner's Manual (see section entitled: Folder Levels). So larger cards may be accepted, but they don't buy you any additional usable capacity.
HTH,David
specialist23
really? i probably have about 5 gigs of music on mine and everything seems to work just fine. oh well, whatever works.
inteller
Car: 2008 EX35 Journey AWD
do you have nav?
dividedhighw
... and also, how many songs do you have on that card?
If you encode your digital music at a high bit rate, the files will be larger and require more space, that's a fact. But, you will still be limited by the restrictions of Infiniti's implementation, as documented.
Cheers,David
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
