nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Thu Jan 09, 2014 4:22 pm
So my 2004 Pathfinder LE is a few months old to me. When I bought the truck it had 114k miles on it. The temp gauge was reading low, my scan gauge reported a fwt of 130-150 after being driven for over ten minutes. I had a p0128 error code. I drained all my old coolant, pulled the thermostat and sure enough it was stuck open. I replaced it with an autozone duralast thermo myself (I did the procedure correctly). I filled my radiator, bled the system, and figured problem solved.. Well now my pathfinder consistently runs at a minimum of 204 degrees Fahrenheit and peaks around 221. This seems too hot to me especially with the recent cold temperatures outside reaching -3 in KY where I live and drive. It hasn't overheated fully and the gauge in the dash reads below halfway. Its not my scanguage because it works accurately in my 99.5 PF and anything else I plug it into.
I measured the temp of the coolant coming into the radiator with a very accurate infrared thermometer. It read around 200 when the scanguage was reading 214. 200 seems normal for the return line. I struggled to get a good reading from the new thermostat as its kind of hard to get at with the engine running but I usually got around 155-170 fwt at the thermo. This also seems normal.
I have no leaks and recently replaced my cap with one from the dealer. I had the dealer bleed the system to rule out error on my part. The only thing I haven't done is pull that new thermo off and test it.
If I can't figure it out, I'll take it to the dealer again and have them diagnose and fix whatever it is so there goes $200 at least. I thought I'd ask here first and maybe save some money and time. Anyone had this issue before? If so what fixed it?
Thanks guys. I love this forum.
nickelghandi on Fri Jan 10, 2014 9:40 am, edited 1 time in total.
