from fmu to safc +370
IanS13
hello i have a blow trough setup now with fmu that works good but, i know that the fuel setup is basic. so want to get it a little with a safc and some 370cc am looking to turn the boost up to over 10psi o just want a more stable setup. so what am i going to have to change in my setup top get the safc and 370's to work, am i going to have to run a pull trough setup now.
Structure240sx
if the maf is working now then it will work after you change the setup.
IanS13
so you mean i can run the blow trough setup and use the safc with the 370's, if this is tru will the maf be able to handle 8psi or 9psi
IanS13
Structure240sx wrote:if the maf is working now then it will work after you change the setup.
what are you saying install the injectors and the safc and leave the maf were it is. am sorry am so stupid but walk me trough this. am searching the site looking for a setup i can use as a basis.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
What turbo?
370s max out at ~250rwhp or so...10psi from anything larger than a T3 will probably break the 250rwhp mark, if it's tuned properly.
Point is, you may need more than 370s...
- Brian
:: orion ::
Oh...and the blow-thru setup should work with the new fuel injectors and such, if it works fine now.
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
im guessing that the fmu will help those 370's to about 300hp by raising that fp
Warped
btw what ratiop are you using on your fmu?3:1?
SoCalSilvia
Car: S14- 1995 240sx
hey bro, do you have any pics of your blow through setup? I am going to be using a FMU and I want to use a blow through setup as well so I can vent my BOV to the atmosphere. pics would be great, thanks man.
[email protected]
IanS13
am not going to run the fmu with the 370's am going safc2. right now i have stock 270's and the fmu is 8:1this is a old pic i will post up a new one tomorrow.
SoCalSilvia
damn... thats a clean engine man, looks sweet. Can you get a pic that shows where the BOV and the MAF is? THat would be great man, thanks!
IanS13
new pic's
BOVBay
MAF
