ricers1 wrote:as the title states.. thats my plan. my stupid ca blew up a while back and ive decided to go with a ka (cheap, easy to find parts, not an SR)
ill be rebuilding the engine either way, im looking to put out 500hp at the wheels.
any recomendations on parts that would need to be upgraded? i.e. will the oem crank hold that much power, reliably that is, or should i build the entire motor. money doesnt really matter...
That's the same route I wanted to take, only problem is, KAs are a more rare item around here, than CA18DETs are in the US. Torque > RPM.
From all my research about KAs, OEM crank is fine even for higher whp, but have it balanced. Forged pistons. Rods might take that power, but with the price on a set of Eagles nowadays, I think there's no point in taking that risk. Apart from that, the usual: injectors/pump/larger MAF/FMIC/recirc. BOV/ECU tune, etc.
This kind of sums it up:
adding-a-turbo-to-a-stock-ka24-noobs-read-t226410.html
On a side note, did you get a chance to measure your now unneccessary CA crank?
