No. Have you checked your ecu? Just because it gives a code 55, it doesn't always mean that everything is okay. It just means that most of the critical components the ecu was designed to monitor doesn't report faults. If you think your ecu is good, then your wiring job is suspect. Remove the crank angle sensor from the timing cover but keep it plugged-up, then with your ignition in the run position, rotate the shaft on the crank angle sensor and see if you hear the injectors pulsing. If they don't pulse, you could have a failed injector driver in the ecu (happens when you buy an ecu from someone who had troubles with their own swap and possibly screwed-up the ecu before it got to you) or again, crappy wiring job.burntricer wrote:anyone?
Nope, they are pulsing.... what could cause them to not squirt tho :Sboost_boy wrote:No. Have you checked your ecu? Just because it gives a code 55, it doesn't always mean that everything is okay. It just means that most of the critical components the ecu was designed to monitor doesn't report faults. If you think your ecu is good, then your wiring job is suspect. Remove the crank angle sensor from the timing cover but keep it plugged-up, then with your ignition in the run position, rotate the shaft on the crank angle sensor and see if you hear the injectors pulsing. If they don't pulse, you could have a failed injector driver in the ecu (happens when you buy an ecu from someone who had troubles with their own swap and possibly screwed-up the ecu before it got to you) or again, crappy wiring job.
Dee
Reversed fuel lines? Upside down fuel filter? Busted FPR? Bad fuel pump? If they pulse but dont squirt then they arent getting fuel pressure. Injectors are simply valves that open and close (pulse), if they arent squirting fuel either all 4 are blocked with something inside them or they arent getting fuel directly pressurized by the fuel pump.burntricer wrote:
It doesn't matter what mode it in, it's will still run. Check your connections, the sensor or again, the wiring.burntricer wrote:If the ECU showes codes, in mode III will it make it so the engine doesnt start? im getting code 13 for the CTS
