loystock wrote:Time varies, depending on the outside air temp, whether the car is in a shade or under the sun and the cooling/heating capability of your system.
Raise the hood, start the car, open the driver side window and turn on the A/C. Verify rear passenger vent is open. Select Fresh Air, Max Cool (lowest temp) and Mode to Center Vent. Once air from center vent is cold to touch, spray Frigi-Fresh on the A/C air intake (below windshield) until you can smell it coming out of the center vent. Then change mode to Foot Warmer, spray Frigi-Fresh, change mode to Windshield Defroster and spray Frigi-Fresh. Do a similar process in Max Heat (highest temp). Repeat process as needed. I spray less Frigi-Fresh while in Max Heat.
When you spray into the intake duct below the windshield you are just spraying to the top of the cabin filter, it may be more effective if either you a. removed the filter. or b. remove the filter and spray from that spot where you remove the filter behind the glove box
I'm gonna have to give this frigi-clean a try. Reminds e of the movie "Me. Myself, and Irene" you know the scene if you've seen it.
