friggen thieves.... (left me with issues)
krazy13
Car: 1991 nissan 240sx se
Hi everyone, I am suffering from a problem. My s13 was stolen 2 years ago and I recently got it back. (Thank you sweet god... :biggrin: ) However it did come with a hitch. The car was basically intact. The battery was dead, and the clutch pedal was basically hitting the floor. I diagnosed and fixed the no start thing. That was easy. Just needed a new battery and fired right up. The clutch pedal thing... well... I replaced the clutch master cylinder (just in case) and the clutch slave cylinder (because it was blown). I have attempted to bleed the system with dot 3 brake fluid (It seems weird to me but that's what the manual said.) And still no improvement. Am I doing it wrong? I know the clutch dampener is still in place and I found another drain point there and I probably need to drain that too I guess but I just want to make sure its just an air bubble and not something else. Please help oh car gods.
krazy13
Anybody? Please? I really miss driving this car and I am confused.
TheRoadShark
Car: '93 S13 Coupe
RB25DET S2 @ 10psi
Silvia conversion
The clutch dampener setup on these cars seems to be notoriously difficult to get bled. Many people like to ditch the stock dampener setup in favor of a direct line for exactly this reason. Keep at it for now, and make sure your master resevoir stays full so you don't accidentally suck air back into the system.
