Friends car. Smells like oil and gas. and idles fine, rev it, it dies
w1ngzer0
Car: Pfft. i don't own a box
What is it? Old gas? some maintance? whatcha guys think?Friends car. Smells like oil and gas. and idles fine, rev it, it dies.
navysnail
check around the injectors, sniff around them to make sure they arnt leaking. also, clean the MAF, do an overall tune-up if your up to it and one hasnt been done in a while.
(i am assuming its a 240?)
w1ngzer0
ah figured. yah its a 240sx with a ka24e? i dunno im not there. I just want to give my friend some ideas on what to do.
navysnail
yeah, i have an SOHC too, i had to replace all 4 of my injectors when i bought the car. look around the base of the injectors were they meet the intake manifold, if it is wet or smells of fuel, start by replacing the seals. if that doesnt work, the injector itself may be leaking, and any fuel leak should be fixed ASAP, as it poses a very big fire hazard, especially with all those electrical connections around it.
w1ngzer0
hmmmmm. wonder if thats my problem. But the exhaust smells like gas more then my engine bay.
navysnail
if its the exhaust, then it may just be running rich, although exhaust *usually* smells like burned gas if its rich rather then raw gas. give it a good check, and the coolant temp sensor is also a good thing to check if you have a multi-meter handy because it can really mess with your car if its bad since it is responsible for enriching the mixure when c old.
CDE
Car: 1989 240SX
A quick way to check injectors is just to give them a wiggle when the car is running. If the car sputters or does something funny, it's the injector. I had to replace 2 of them when I bought my 240.
s13sr20chris
also, check igntion and valve timing. jumped time will sometimes act just like that. low fuel pressure will too.
w1ngzer0
what would cause low fuel pressure?
s13sr20chris
pump going out will do it but a restriction or bad regulator could also be the culprit. pump is the most common. check the pressure if you are able otherwise just time it to see how much of a 1 liter soda bottle she fills up in one key cycle.
w1ngzer0
i don't know where the fuel pump is i had the oil and water pump replaced resently.
I also had some weird dream my car was spitting out white smoke agian. Then i woke up feeling ****ty. lol
s13sr20chris
its in the gas tank. you can access it through a cover in the rear hatch.
w1ngzer0
can someone help me with a picture on where the coolant temp. is at? i have an sohc.
s13sr20chris
i will try to get a pic asap. in the meantime, its on the intake manifold in the front. it has a yellow(usually) connector and has two wires. it is right next to the one wire coolant sensor that just runs the temp gauge.
ricebike
2002 Quest
2005 Altima
you'll see that yellow warning sticker next to the air bleed bolt, saying something like "do not open it while hot"
the red colored square plug w/ 2 terminals
oh, pic courtesy of...
http://www.240sx.org/links/ins...x.htm
the search of pics in members rides sux, so found it this way
w1ngzer0
I am finally in nor cal and saw my friends 240sx. I will be trying these few things. I saw in that other post about the oil smell in the oil.
Fix the running rich part first. Its not injectors becuase i shook them all no studder or anything. They are solid injectors. Going to run a fuel pressure and compression test sometime this week.
Then do the normal maintaince. Thanks a lot guys i'll keep you updated on what happens
