Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Tue Apr 11, 2006 6:21 pm
Check the IACV, back out the idle screw almost all the way to see if you can get the idle to run up high enough.
Try unplugging the MAF and starting the car. If it starts and idles smooth then you have a bad MAF. It should rev limit you to about 2000 RPM.
Test the TPS voltage. Adjust as necessary.
Check for leaks in the piping, and other vacuum leaks. Make sure the BOV is a closed system if it is stock, if it isn't then you need to remove it and block it off or close the loop.
Set the ignition timing (15 BTDC - 2nd mark from right). Might have to pull the CAS if you can't get it to straighten out.
