friend has a problem with his maxima
JDMZ32
Car: 1991 Nissan 300ZX NA slicktop 5spd red
hello from the Z32 fourm. he says simply put, the clutch pedal is sticking to the floor. he thinks it may be the master and/or slave cylinder. maybe you guys can help him out? thanks!
kzoosho
Car: Turboed 1997 Nissan Maxima SE
For one he is out of fluid i bet ya and two there is a line that goes from the distro block to the slave that leaks. Get a ss replacement one piece line then bleed and he should be ok.
redrelyt12
Car: 2000 Nissan Maxima SE 5spd
Hey, I'm the one who owns the max. I have had this problem before but the first time was an easier fix. I was out of brake/clutch fluid. This isn't the case this time, but I'll check that hose and under the car to see if there is a leak. More detail to the problem is that I'll depress the clutch and it will stick to the floor. I'll pull it back up and pump it a few times to get it to work. As I drive, it gets worse and worse until I pump it a few more times, while driving or at a light. Any other ideas what it could be? Thanks in advance.
kzoosho
redrelyt12 wrote:Hey, I'm the one who owns the max. I have had this problem before but the first time was an easier fix. I was out of brake/clutch fluid. This isn't the case this time, but I'll check that hose and under the car to see if there is a leak. More detail to the problem is that I'll depress the clutch and it will stick to the floor. I'll pull it back up and pump it a few times to get it to work. As I drive, it gets worse and worse until I pump it a few more times, while driving or at a light. Any other ideas what it could be? Thanks in advance.
As i stated you have a leak more than likely its the line from the distro block. I recomend the stainless steel one piece line. Also see if there is fluid on the floor in the car . If so then you Clutch master cylinder is leaking. Look on top of your transmission to see if there is any leaks . If so your slave cylinder could be leaking.
My money is on the line leaking.
redrelyt12
Well I'm guessing that you're right about the leak on the line. There is no fluid on the floor of the car, none on the pavement under the hood, and i didn't see any visible on the transmission. I just tried to start it up again, and the pedal was again sticking to the floor, but pumping it didn't help. I managed to take it out of reverse but I couldn't get into any other gears.
JDMZ32
welcome to NICO, buddy.
redrelyt12
haha thanks stephen
JDMZ32
