allenms240 wrote:I was recently fumbling around in there. I agree, I think it just threw off a connecting rod or plastic pin, you'll have to look at it with the panel off to get a better idea of what's wrong. One day when I got home and parked the car, I pulled my handle and the stress (20yr old clips ftl) snapped the clip, and the way it fell, jammed me in the car. I couldn't open the door from in the inside or the outside because the way the rod fell jammed the lock. I had to take the door panel off (which will be a biatch with the door shut FYI) and then got it fixed an hour or so later with various zip ties. Let me know if you need any information when you look at the inside of the door.
well... im pretty confident it will be easy to figure out what to do when the door panel is off, cuz its just a matter off folowing everything and what not, but how did you get the door panel off with the door shut? thats what i want to know
ill cut/rip the panel if i have to, since mines not in the best shape anyways, but i dont have the money for a new one right now and id rather do it without screwing it up if i can
