S12_hybrid »
https://forums.nicoclub.com/s12-hybrid-u41151.html
Sun Jul 08, 2007 4:44 pm
Alright now I know this is not the standard swap, but lets be honest: The wiring of these things isnt THAT complicated as long as you get your grounds and power from ignition right.
Apparently though, its too hard for me..
Engine is an R33 Rb25det Series 2.
Hooked everything up as best I could, this included:
-Ignition switch went directly to a junction of power wires on the harness-Start switch was left connected to the old lower harness, I just swapped it onto the new starter.Off the fuseblock I ran:-ECU power to pin #45 (If I remember correctly) this was a 10 amp fuse-Continuous ECU power taken from the clock un-interupted power
The grounds which are located in the harness (By the injector clip) were grounded to the manifold.
The Relay is engaged by ground activation via the ecu. The ECU itself received switched 12v power from the ecu fuse (off the fuseblock, as I mentioned).
When I spun the key to "ON" my ECCS relay engaged, and all seemed well..
Then a few seconds past - the relay did not disengage - and smoke started billowing from the box.
It appears that i melted the area around pin #47 to #50 and #59 & #60. Just as a reminder, these are the main switched 12v power lines..
So, I check all my connections, make sure i've got continuity on grounds, and no 12v where there shouldnt be 12v..
I ended up finding that there was 12v on pins #26 & #27 - these are maf sensor lines - I do not know the internal workings of the MAF in depth so DO these lines need 12v??
There didnt appear to be any shorting on the MAF lines, but I dont know..
Also, do these ECUs need to have their case grounded? Are there grounds that I could have missed?
I will get pictures asap!
Oh and just for ****s and giggles, here are the specs on the car.
1987 Nissan 200sx coupe-Stance coilovers (GR+)-S13 rear subframe with J30 LSD and axles-walbro 255-Z32 TT rear brakes & parking drum-180sx front brake conversion-All around 5 bolt conversion (Ichiba in front, 300zx in rear)-Bings Tension rods-Bings Adjustable tie rods-30x12x3 FMIC with mandrel bent intake piping-Greddy intake manifold-Q45 TB-AE86 seats-1 piece driveshaft (steel)-Wilwood biasing valve-Homemade CO2 intercooler sprayer-S13 coupe digital gauge cluster-Prosport gauges (Oil pre, fuel pres, Boost)-Will soon have a full 3" custom exhaust (DP to tip)-Headlight conversion (eliminated pop ups)-17" RTX rims (Whatever I could find cheap with decent rubber)
