gs14racer »
https://forums.nicoclub.com/gs14racer-u58274.html
Tue Oct 07, 2008 2:35 pm
Ok long story short i miss-wired one of the coils backwards and fried the coil, and in turn i think ecu. positive went where it was supposed to, but i mixed up the ground and ignitor signal wires.
The ecu power light wont turn on unless i manually ground the eccs relay, and the fuel pump wont come on no matter what, Once i manually ground the eccs relay i can get the ecu to turn on and pull codes, i get
11 cas 13 ect temper ( not connected ) 54 a/t comp
You guys think i fried the ecu?? I can get the car to do nothing but crank and crank no matter what, also you think i fried the cas too??
And yes the coil popped, it was pretty violent lol
