mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Wed Aug 29, 2007 4:25 pm
Nah, I'd find it more likely to be air in the lines. If the clutch were burnt up I would think it wouldn't be engaging until the last part of the pedal travel due to wear (disc gets thinner, clutch pedal has less travel needed to disengage therefore only needing the first little bit of pedal travel to engage).
If air were in the lines you would press the pedal, building very little pressure till finally at the last portion of the pedal stroke there's enough pressure against the pressure plate to disengage the clutch.
