H00NIGAN »
https://forums.nicoclub.com/h00nigan-u207633.html
Tue Jul 31, 2012 11:21 pm
I would like to start off by saying Hello to everyone as i am new to this forum..
I just rebuilt a s14 ka24de pretty much a OEM rebuild, Has ARP main studs, Rod Bolts and Head Studs and Clevite bearings. Everything else is stock or OEM. I got motor complete and running, but it running weird and is throwing me for a loop trying to figure it out.. It is missing at idle and brakes up untill 3500rpms then it seems to clear up but bogs and slow to climb rpms.. I bought and replaced wires, plugs, distributor, rotor,cap, ignition coil. I switched out my MAF with a working on off my other 240sx and nothing changed its still the same..This is a s14 ka but i used a s13 Intake manifold, because it all ready had EGR delete and all the emission deleted, Could this be the problem? I had a friend tell me i could not use a s13 intake on a s14 ka.. Also my car was swapped from single cam to s13 dual cam, I am still using s13 wiring harness and ECU and Distributor. This motor also has the dual exhaust cams in it and i am sure they where installed correctly i triple checked everything...Any Ideas Please Help..
Thanks..
Chris
