chicos240 »
https://forums.nicoclub.com/chicos240-u20799.html
Sat Apr 21, 2007 7:43 am
before you go screwing w your timing. Try thisTurn off car.Disconnect TPS.IACV Valve.Close it all the way.Back it out 3 turnsTurn car onSee where it is idling. If its still fast, turn the IACV screw in half a turn and wait 30 secs, repeat if it is still fast. If it is too slow on idle then back out half a turn.Once you get it where you want it, turn car off.Reconnect your TPS Turn car back onit should stay at idleIf it does notTurn off car and disconnect your throttle cable, turn car back on and see if it idles better. Could be your cable is not well adjusted.
