fresh sr rebuild problems, need some ideas.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
So my buddy and I rebuilt his motor with some aftermarket parts and it has good compression all, the way across the board at 160 psi. However it does not idle or rev. I can hold the throttle wide open and it doesn't rev the engine. I also have to hold the throttle almost wide open to get it to stay running. Is it possible to have a cam gear off a tooth but still compression test with good results? We also checked fuel pressure witch according to the electronic gauge is at 45 (I know, it is high but would cause this).and we have given it alternative fuel when its running to see if its fuel related with no change. Also, if I remember right all coils ohm out within spec. Any ideas/comments..... Bring it on!
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
I would say your probably off on the intake side and just cant get enough air into the cyl. just my .02
compactfean
daily
That's kinda what I was thinking was one of the cams is off, ill check that out. Just wasn't sure about the compression test.
moso
90 240sx ka24de RIP
you could still get good numbers if the valve is opening and closing early.
compactfean
daily
Pulled the valve cover and sure enough, intake cam was advanced one link.... Thanks dawg! Lol.
