91white_ka »
https://forums.nicoclub.com/91white-ka-u134171.html
Sat Sep 12, 2009 1:38 am
if your off a tooth it usually wont even idle, 140 is low compression, I'd look into that, esp with new rings. My bet is your dizzy is off, get a timing light. Also check to make sure all grounds are tight and everything is plugged in, might now even be a timing problem.
