float_6969 wrote:I know you don't want to hear it, but it sounds like improperly installed/gapped rings. Test the compression and let us know how it comes out.
Also, all of you saying you need an easy break in are full of it, IMHO. My break in procedure consists of warming the motor up to NOT, then full throttle in 4th to 3K rpm, then engine break back down to 2K, full throttle to 4K, engine break to 2K, etc until I reach redline. After that, I drain the oil, replace the filter, and the motor is broken in.
My motor was reading about 190psi across the board when I took it apart with 40K+miles on it. (failed oil filter ruined the head, main, and rod bearings) I have every intention of doing the exact same thing to this build once it's done.
The engine breaking in gear is important! It helps pull any metal off the cylinder walls to keep galling and over-wearing down.
Hi
Questions from Australia!
What is NOT?
I am going home this afternoon to put the final touches on my motor, and start her up for the first time.
Here are the specs and work done:
• Head sandblasted and cleaned
• block bored 40thou and honed
• Head machined
• block machined
• JE SRP forged pistons
• new piston rings
• new big and small end bearings
• new water pump
• new head bolts
• new timing belt kit
• new genuine Nissan oil pump
• Full durapro gasket kit
• new intake and exhaust and turbo gaskets
The oil i am going to use is a Penrite Running in oil 15-40w.
I will be following a similar method to yours - except i have been told to 'baby it' by a few people.
Also, how long should i use the run in oil for? I was thinking just to do the load, then engine brake, then load, then engine break etc.
Any advice appreciated.
