jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Sun Mar 19, 2006 10:04 am
well the seals might not be on properly or the valves arent seated properly in the head.
well i mean, i would say, if this rebuild was the reason for its poor starting, u really should consider removing the SR and inspecting it again. as long as u know u are getting air, fuel, and spark, then proceed to test it as follows:
for inspection-compression test -cylinder leakdown test (to see if valves are opening and closing properly)
for rebuild-lube the cylinder walls-inspect the piston rings-inspect entire valvetrain
let me look through my notes just one more time and ill let u know exactly what u can do. ill get back to you soon.
