fortwayne240 »
https://forums.nicoclub.com/fortwayne240-u41562.html
Sat Jun 16, 2007 6:43 pm
Yet another Post about problems... and I have searched, but with no solutions....
Ok, here we go....A fresh rebuild, all new EVERYTHING, all new timing chain and components, CP Pistons, Eagle Rods, Tomei Head gasket, yada yada... my basic setup is as follows
2871R .64 a/r300zx maf740 tomei injectors255 walbro fuel pump264 intake cam272 exhaust camgreddy intercoolerAEM Fuel press. regulatorENTHALPY ECU Tuneetc...
I am having a studdering problem right around 4000 rpm's and above durring wide open throttle..... right around the time I hit full boost. (right now @ 9 PSI)
As I watch my AEM wideband, it starts off at about 11.2 AFR and holds steady.... as I get to about 400 rpm's it suddenly drops to right around 16.0:1 and then goes to 17.0:1 and then the car starts bucking and jerking all over the place.....
I have checked the TPS, coolant temp sensors, the CAS, the spark plugs and coils, the wiring, the MAF sensor, fuel injectors, fuel pump pressure, timing, checked for boost leaks, etc... al check out according to the FSM.
I believe that the problem is something with the fuel system, such as fuel pressure or fuel injectors. I have tried correcting the problem using my S-AFC all the way up to 50% and it still happens..... any suggestions ?
I am going to go out right now and disconnect the S-afc completley and see if that is causing any problems....
Help is appreciated, so thank you in advance....
