papachrizzle wrote:i have a freash rb20 swap in my 1991 240sx..
....but i get power everywere but to the coil packs...
any suggestions?
I had problems getting my wiring right when I first installed my RB20DET. For testing purposes, pay close attention to "WHAT" each wire is, and directly apply what it needs ONLY if you know what you are doing. For example, a wire that expects a constant 12v and a wire that expects a switched 12v on the engine side of the harness splicing can be touched to the POS 12+ battery post, etc, etc,
This kind of testing may help you narrow down which wires are wired correctly and which aren't. Or you can check (with a friend turning the key to "start") your known wires and make sure they are getting the expected voltages..
--TJ
