fresh rb swap not starting
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
ok so we did a rb20 swap on my friends car the last 3 weeks, now we have everything ready but the son of a ***** will not start, its getting fuel but no spark, so we try a dif ecu, dif ignitor chip, and a dif CAS and still no spark, when we turn the cas by hand we can hear the injectors click.
so we presume its wiring, but we have all the wiring hooked up the same as my rb swap wiring and mine runs fine. we extended maf wires, extended exhaust o2 sensor wires, swap from the rb 6 wire to the ka brown and grey wires, and under dash wires we have tach, speed signal, temp gauge and start signal all hooked up.
so any ideas y its not starting?
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Perhaps the bread is too fresh. You need to let it settle for a bit.
On a serious note did you check your spark plugs? Perhaps even your timing?
d356bud
Car: 1990 240sx w/ RB25DET
so ur tach does move when u try to start it?
BoostFab
Car: S13cp, S13fb, S14z
my 5 points-checks for no spark:
check the coil's harness grounded
check the motor grounded good ?
check efi fuse;
reseat igniter plugs; and cas, plugs all the way tight;
check power to the coils;
driftmyke
nizmo zilvia wrote:Perhaps the bread is too fresh. You need to let it settle for a bit.
spark plugs are brand new. how do i check the timing? the cas is set correct.
d356bud wrote:so ur tach does move when u try to start it?
idk im always by the front when we try to start it ill look tonight and check back
BoostsFed wrote:my 5 points-checks for no spark:
check efi fuse;
coil harness is grounded, but ill doublecheck
motor should be grounded
havent checked that fuse so i will tonight
polugs have been checked and are tite and making connections
how do i check power to coils?
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Check the center wire, make sure it gets constant power...
Also, if you are not getting spark, make sure you have the 2 wires hooked into the ecu..
1 gets put in between the 2 green relays, 1 sends start signal to it...
driftmyke
Acecool wrote:Also, if you are not getting spark, make sure you have the 2 wires hooked into the ecu..
i dont understnad what ur talking about, please explain.
S13 240SX
Car: 93 Mazda Miata
what he is talking about is that there should be 2 big green relays on your rb20 harness near the ecu. are they there and hooked up and clicking, when you try to start?
Acecool
That would be them :-)
APL
Car: 1991 Nissan Skyline Gts-t
Did you figure out the problem?
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
Check for continuity between the ECU and the ignitor and then from the ignitor to the coil packs.
I forget which pins they are exactly but just look at the wires that are plugged into the ignitor (lets just say one is a red wire with yellow stripe), go to the ECU and find the red wire with yellow stripe and hold one of your probes on it, hold the other probe on the wire where it plugs into the ignitor. Do this for all the wires. Then go from ignitor to coils.
SIL-LINE
Car: S-13 With RB20det
Try and check the bolt on the big blue plug (ECU) . If the bolt is not in the whole way , it can be no or poor contact ..
mattleegee
Car: s13+19 corolla
this ever get resolved?free bump since my swap wont start either
Acecool
Check my videos on Youtube, if you still cant get it started send me a pm and I will see if I can help :-)
