Fresh OC
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Just did an oil change using Mobil5000 & M1 Oil Filter.
Smoothed out just about everything, engine, trans, brakes, steering.
Its just that my mileage seems to have dropped badly. I haven't crunched any numbers but this is not working.
Yesterday, I took two trips, in two Qs, Same 45 mile trip. The M1 oiled Q took a whole 1/4 tank while the other Q's fuel meter moved down 2 strands of hair. Both gassed at same station to just over 1/2 tank.
Always used Valvoline 10W-40 non-syn. The M5000 oil is 10W-30 -- could that be the cause of the drop in mileage?
Modified by Kiven422 at 4:52 PM 11/3/2008
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
10W-40 is a thicker oil compared to 10W-30 so you should have had worse mile with the thicker oil.
The thinner the better with oils, more lube for the top end.
Your problem might be due to something else.
qship96
Car: 1996 Infiniti Q45
everything in your above paragraph is just wrong!!!!!!
Infinitiguy19
Well OK the MPG may not be all that bad with a little thicker oil.
But whats else is wrong with my first post?
qship96
My post was to the original thread starter....oil change made his transmission,brakes,steering,engine smoother-----IMPOSSIBLE
Paul your comment was correct, a 40w oil would, if measurable,show slightly lower MPG than a thinner 30w oil.
Infinitiguy19
O I see.
He might have meant that the car just felt smother over all because he just had her serviced, Sort of like a placebo effect.
Kiven422
'94 Infiniti Q45t
After the oil change, the transmission shifts more responsively, the steering is smoother, I had a slight unnoticeable vibration that I couldn't fix, now its fixed. The brakes also feel better just cause!
I may go back to Valvoline, which has always satisfied me in performance, mileage and extended OCI.
But never mind that... whats up with the decreased mileage??
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Better quit smoking what the mechanic leaves in your ashtray.
OCI affects none of the phenomena you posted.
qship96
Maybe he put a little motoroil in the transmission and PS resivour!!!!
Kiven422
'94 Infiniti Q45t
Oh man you caught me! I totally put some in the PS but I can't explain why the transmission smoother? I mean I totally didn't put it in the TRANS.
Maybe if I wasn't at work I wouldn't be wasting my time here.
Thanks anyways
Infinitiguy19
Maybe because the engine is running better/smother your transmission will run better.
I haven't driven your car so I have no idea.
The power steering i have no idea either.
mcrews
Car: 2002 Q45 Sport
93 Q45 (Mafia cruiser)
94 Q45tStillen Intake, Magnaflow Dual Exhaust,
here are the poster's Qs......now. we don't know which one had the oil chjange but the gas milegae problem seem selfexplanitory.
Changing engine oil will not make a transmision smoother.It will not make brakes work betterIt will not make power steering work better.
The M1 oil may improve mileage, but only over time. Not on a short trip.
Kiven422
'94 Infiniti Q45t
Issue fixed. Thanks. Mileage is back to an acceptable level again.
A vehicle that doesn't see oil changes very often will be smoother after a fresh oil change, its common sense and its also something you can feel in the car.
Don't matter if you disagree. I'm just telling you like it is.
BTW probably won't put the intake on unless I start craving the sound again.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Kiven422 wrote:A vehicle that doesn't see oil changes very often will be smoother after a fresh oil change, its common sense and its also something you can feel in the car.
Cessation of vehicular abuse seldom yields any improvements beyond the termination of the abuse.
Infinitiguy19
in layman's terms of what Maxnix said:
Just change your oil often (every 3000 miles) and you wont have that feeling of "yay everything is all better" for 100 miles you will have it all the time as long as you maintain the car right.
You make the car happy and the car will make you happy.
NightRiderQ45
Car: 1998 Infiniti Q45
maxnix wrote:Better quit smoking what the mechanic leaves in your ashtray.
LMAO! Exactly!
