hotbox240 »
https://forums.nicoclub.com/hotbox240-u63022.html
Fri Apr 20, 2007 4:16 pm
Hey guys I've been lurking in these forums for long enough so I figured I might aswell sign up since my ka-t project is done. My problem...it won't start, stats are as follows:Phat KA-T manifold & downpipe Garrett T3/T04E 57 trim 0.48 AR turbine side Tial wastegate (6 lb spring) JGS oil lines & Vacumm blockXS power intercooler kit Custom 2.5 inch hotpipe Turbo XS RFL (recirculated) ebay 3 inch exhaust SR 370cc injectors (in stock fuel rail) Apexi SAFC II (5 in 5 out -25% on low throttle) PLX M300 wideband Walbro 255lphStock MAF (pull through 15 inches from turbo) 100,000 mile stock block Emissions all removed (Pair valve, EGR system, carbon canister, etc.) I've got spark & fuel. I didn't touch the distributor at all during the whole install. My safc is reading 0.2v - 0.3v from the maf when the key is turned on. The only time we got it to start was when we sprayed some carb cleaner down the intake. Really need some input guys, I need this car back on the road.
