psst hey gabby, you had some goofy IC piping too didn't youca18detgabby wrote:the pink was hotter........
the piping is gross....... need to rework it asap.
for short term, i'd deal with it, but if i were you, i'd go to a muffler shop and have them bend some pipe to make it look really nice..i think it'd flow much more smoothly without the sharp corners in there.silviaS13lover wrote:my piping is beast..
no sharp turns......... no flow was restricted.......... goofy? maybe lack luster, but it worked properly and aluminum IC piping VS intake piping is the exact same thing.ragenasian wrote:
i agree with everything said here.float_6969 wrote:Guys, it's not like the car won't run that way, it just won't make as much power as it might otherwise. REGARDLESS, I'll bet you this setup isn't as restrictive as the itty bitty stock SMIC and air box.
stock CA T25?silviaS13lover wrote:i may be going with a different intercooler set-up soon. so until then, the pipes stay. i don't think im running enough boost to even make a difference in power, also if any power loss, it would only show up on the dyno. as of now it makes 201 whp on 10psi.
hmm..i wonder how much i'll get with the CA T25 at 11psi lol.silviaS13lover wrote:sr t25, gtr fuel pump, fmic
Not much. I managed a whopping 198rwhp on the CA T25 @ 15psi w/10:1 compression and a standalone. AND that was on a dynojet, which read high.sjbsuperman1425 wrote:hmm..i wonder how much i'll get with the CA T25 at 11psi lol.
damn dude. frontmount im guessing?float_6969 wrote:Not much. I managed a whopping 198rwhp on the CA T25 @ 15psi w/10:1 compression and a standalone. AND that was on a dynojet, which read high.
that top drivers side corner is my wideband...... I wasnt going to cut and splice that.silviaS13lover wrote:maybe you should wire your bay properly instead of half assed.
the others circled are test wires we were in the process of wiring my AC in. as you can see the battery charger is on the passenger shock tower and the battery isnt even plugged in
