ceningolmo »
https://forums.nicoclub.com/ceningolmo-u33477.html
Wed Nov 15, 2006 10:44 am
Ok... I just changed the diff fluid.
I'm not sure if you all are aware of this but fresh fluid actually makes the Q drive smoother. I know, I know... crazy talk. But, hear me out. As it turns out, if you go out and get the BG transmission fluid flush with synthetic ATF (amsoil) and then change out the diff fluid with synthetic (M1) your Q will drive, shift, and just generally feel smoother.
Fresh fluids? Why, that's crazy talk you say!
Seriously, its well worth it.
On a side note. When you open up the two plugs on your diff and, I don't know, about 2 oz. of fluid drain out you can probably assume your diff has not been running optimally. Additionally, if the fluid that does come out is pitch black and reeks like a dinosaurs ***...the fluid was probably short of ideal.
On another note...planning ahead to have hose of appropriate weight and diameter will make the job much easier. Also, when ALL of the experts on your favorite site (nicoclub.com), as well as several of them via conversations on AIM, recommend that you warm the fluid first in order to help it flow easier... well, ****ing do it you moron! No matter how "not thick" the fluid looks, feels, sounds while it is in the bottle... I assure you, it is in no particular hurry to go through a hose and in to your diff.
On yet another note...if you happen to be a moron. I'm not going to verify whether I am a moron, but I am going to suggest that it is a possibility. If your moronocity happens to leave you with non-warm fluid (and, by non-warm of course I mean ice ****ing cold since I left it them sitting on my garage floor while it is 40 degrees outside) and a hose that is really long and slightly too narrow to properly carry the fluid, here is a solution to your problem.
Solution1. Trim nozzle of bottle and attach hose of inappropriately small diameter.2. Crawl under your car and hold the hose in place so that it doesn't fall out of the open plug in your diff.3. Have your wife STAND on the bottle of diff fluid thus forcing it through the hose and in to your diff.4. Spill at least 1/2 quart of fluid on your garage floor, hands, hair, and potentially wife.5. replace plugs, start car, drive around with large smile on face.
