The threads about replacing a radiator either make no mention of the Fresh Air Intake mounted to the radiator, or simply say "remove fresh air intake". The latter is my problem, I don't want to break anything and am puzzled by how to remove it.
The Service Manual is useless, it does not even show the Fresh Air Intake in the parts diagram. The cooling section tells you how to crimp on a new radiator top but makes no mention of removal. I searched every pdf of the various sections and found a few 'fresh air' references but none of them were for the radiator/air filter box.
The fresh air intake of my wife's i30 as shown at
https://imgur.com/uYwJ6sr has to be removed before anything can be done with the radiator.
The intake channels air over to the air filter box and fits over an external airbox fitting
https://imgur.com/6CX15oY. There appear to be no clips to relase or press to open, it looks like twisting a joint knife in the gap will push the fresh air intake off the airbox.
Sounds easy, but there is a gotcha as seen at
https://imgur.com/LAfsDDs, a T drops down to a rigid plastic elbow which has an open rectangle that appears to be snap fitting that has to be pressed in. I tried pressing a screw driver against it without success.
If anyone on the Forum has removed the Fresh Air Intake, I would very much appreciate their advice on how to remove it.
