Gerardjg »
https://forums.nicoclub.com/gerardjg-u36599.html
Fri Oct 30, 2009 2:41 pm
No but it is out and I am going to bed, You have to remove the 2 fittingsin the engine compartment and some mount bolts inside and the plastic housing and evap coil slide out as one .
I did not need to remove the blower motor I did find the below instructions on another web site .
10.Remove the evaporator assembly as follows:A. Disconnect the high and low pressure tubes from the evaporator assembly.B. Disconnect the harness connector from the blower motor resistor (as necessary).C. Remove and save all mounting hardware.D. Remove the evaporator assembly.
